Creation of the socket used for interfacing to netTx failed.
Using show port statistics command, ensure that the ports are in the correct state. Check memory usage using 'show memory' before switch reboot
Error
Failed to create raw socket for netTx. return code %code%
| Name | Type |
| code | uInt32 |
